Putting a 6.5 in a 84 blazer?????
Discussion in '1982-Present GM Diesel' started by braunm, Jan 7, 2002.
  1. braunm
    braunm Registered Member
    May 26, 2001
    77
    Is it worth the work to put a 6.5 in place of my 6.2? it is a stock m1009 blazer. Soon I will have a 14 bolt and a 60 and a 4" tc lift with 36" tires. Any help would be appricated.
    Mike
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I was thinking about doing the same when my 6.2 dies
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    From what I have heard a 6.2 with a Banks turbo and exhaust will out power the 6.5
    Corey 78K5
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    6.5 turbo or 6.5 NA?
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    6.5's have improved (bigger=more power) valves, redesigned prechambers, stiffer bottom end, improved cooling, (later style) oil cooled pistons. Naturally aspirated the do have a slight performance advantage (but a 6.2 will have better mileage). The real advantage arrives when they're turbocharged, where extra beef and cooling allow more boost/load.
    By the way: M1009, one ton axles, 6.5 OOOOooooohhh yyaaa!
    Real trucks don't have spark plugs!
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    What tranys can you put behind the 6.5?
  7. 84M1031
    84M1031 Registered Member
    Jan 10, 2002
    47
    PT. Pleasant New Jeresy
    I was hoping it would bolt to my turbo 400. 6.5 is a na (for now)
    Thanks for your replys.
  8. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    The 6.5 will bolt to a turbo400, 350, 700r4, 4l60e, 4l80e, sm456, nv4500, and more.
    84k20,18:1- 6.5td,400/208,4.10,4",35"s
  9. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Great thanks, that gives me more options.
  10. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Is it true that a 6.5 turbo motor will not fit in the older trucks? I heard the A/C box is in the way...
    Mike
    The jeep eater ......[​IMG]
  11. 84M1031
    Jan 10, 2002
    47
    NEVER THOUGHT OF THAT. I DON'T KNOW. I AM SURE SOMEONE ON HERE DOES KNOW.
    MIKE
  12. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The 6.5 is identical in every way externally to a 6.2. Only the injectors are at slightly different angles. You can install 6.5 heads on a 6.2, and vice versa.
    The 6.5 is a better designed engine than the 6.2. It does have bigger valves, and of course bigger displacement.
    The 6.5 turbo engine has ceramic coated pistons to withstand the extra heat of a turbocharger. The 6.5 N/A version does not. If one is planning to install a turbo later on, I highly suggest you get the turbo version of the engine.
    The factory GM turbo setup for the '92 + model trucks do present a problem for the early body style trucks, because the turbo is mounted farther to the rear of the motor, and the turbo downpipe points straight down. It is difficult to clear the A/C housing on our style of trucks, but it has been done.
    Of course, one can always install a Banks turbo system on the 6.5. The 6.2 Banks system will bolt right up. However, the GM 6.5 turbo is wastegated for better performance.
    Hope this helps!
    Later,
    Casey
    1986 K-10, 6.2L N/A diesel, SM465, NP208, 3.73 gears
    <a target="_blank" href=http://community.webshots.com/album/14911798DvydoACKJE>My Chevy Photo Album</a>
  13. Goodwrencher
    Goodwrencher Registered Member
    Jul 9, 2005
    41
    Burlington, Wa.
    A/C box interference
    Yes the turbo will interfere with the A?C box. But there is a solution. Remove the factory A/C, Either convert the firewall to a flat steel one like the Hot Rodders do, or mak a steel panel to fill the hole. Then install a Vintage, or Hurricane system. Both work 10 times better than the factory anyway. That is what I am doing with my 6.2 to 6.5 Turbo conversion. Then again I specialize in A/C systems and Hot Rod custom work. It's not that hard though and the systems are well worth it. I am a dealer for both, let me know if you want more info. I also have a great product for saggy springs, that double as traction and stabilizers.
    Goodwrencher
  14. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    This forum isn't here for you to drum up business and pimp your parts/services. If that is what you're here for Steve offers a vendor package...
    Rene
  15. Goodwrencher
    Jul 9, 2005
    41
    Burlington, Wa.
    pimpin' parts
    Just trying to help, I know how hard it is to find the right stuff sometimes
  16. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    besides the AC unit there are a few other areas that you have to worry about, The front drive shaft hitting the cross over pipe, the down pipe hitting the frame rail, and the routing of the exhuast pipe. If i get motivated i might eventually post some pictures, but its a pain becuase i have to get someone else to host them for me.
    cheers, rugger
    Goodwrencher email inbound
  17. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah the turbo goes where that box is.
    You can modify it though to work.
