Putting a Blazer Tank into a C-10 pickup 2wheeldrive?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by juanblzer, Jun 10, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I plan on building this truck into a moderate prerunner and I want to keep the fuel tank under the bed (where a blzers tank usually is) is this possible. What types of problems will I run into?
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I had a 72 I did this too but I didn't use a blazer tank, seems like you have to move a crossmember to make it fit. on mine i just moved the crossmember and bought a harwood 15 gal fuel cell. then cut a hole in the bed for the filler
    kinda nice in that you can see what's in your tank and not wonder how much gunk is sloshing around down there.
    but then you have a hole in the bed. but if your building a prerunner it probably wouldn't matter
    just usually a cheaper alternative to the blazer tank. which can be rather expensive.
