Putting acc. hole in head?
Discussion in 'The Garage' started by RingMaster4x4, Oct 18, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I bought a Serpentine belt setup my SBC and I need two more holes in the passanger side head. there are flat spots where there would have been holes. So the question is do you think it is ok to drill and tap two more?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    how many bolts do you already have in the brackets if you have a good number in there already you will be fine leaving them out
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    only one I am sure I need at least one more.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could drill and tap the head but you need to be very careful not to break into the water jacket or even worse the combustion chamber. Just be carful not to drill to deep
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    yeah I am only going to go 1/2 or less
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    no one else has any word of waning?
  7. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    You want the tap to be as perpindicular as possible. I think MSC has tap guides. A tap guide is sort of a bushing that is machined flat on both ends and allows the tap to fit through the bushing (with a little interference)and be used as a guide. I have made a couple on the lathe instead of buying them. HTH.
    T.J.
    www.tjsperformance.com
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the only thing behind the area is the coolant jacket, then you don't have much to worry about. If you get into it, just coat the bolt threads with Permatex before you install them. It works fine for the water pump bolts. :wink1:
  9. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i think 1/2" is not deep enough to get a tap deep enough to have enough threads to really bolt and acc. bracket on...just my honest opinion
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    let me find a picture
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    ok the heads look like these the one on the left is the one I need to drill. my heads have two rased flat spots just like these off ebay.
  12. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    typically if you're interested in doing this type of drilling and tapping, i'd let a machine shop do it who has experience in this type of thing. Otherwise you risk drilling a bolt hole at an angle, or worse cracking a head.
  13. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,614
    602
    Hooper, Utah 84315
    Don't do it its not going to work. You probally only need one hole and you don't even need that. Never did it on mine and my serpintine setup has yet to fall off my motor. Read testimonies of guys who have tried and they want to know how to fix a leaking head.
  14. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    This may seem dumb, but why not just modify the bracket. Can you weld a piece of steel onto it that you could get to line up with one of your existing holes? That seems easier than drilling and tapping the head.
  15. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    the bracket is aluminum and there is only one hole on the passanger side head
  16. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I second this aproach why not make a bracket that you could take back to a manifold bolt even
  17. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    i drilled some holes in a set of camel hump heads that didnt have the accessory holes, wasnt a problem.
  18. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I agree with the guy above me. Several guys I have talked to have had to drill holes in heads that don't have accesory holes.
