putting duallie wheels onto a SRW axle
Discussion in 'The Garage' started by R72K5, Mar 8, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    would wheels and stuff stay in place if you put dual wheels onto hubs of a SRW axle and run them ?
  2. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    The bolt pattern is the same so the will bolt up but I doubt you will have enough clearance to actually get the wheel on due to the huge backspacing. Assuming you have a D60 front, you would be much better off trading your SRW's for DRW's. The hub/rotor assemblies are the only dif between the 2. SRW's are somewhat hard to come by so you should have people lining up to trade.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    what axle are you looking to run a dually rim on?
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    if you have SRW hubs i wouldent trade them... just buy drw hubs if you part with those hubs you will probably wish later that you dident
  5. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    I got a bone stock 60? rear in my 71 GMC truck, to get the "duallie" wheels to fit in my pick up bed I had to move the fender wells in 3in. on either side and strech the wheel houses. But other then that they've been on for over 10 years no prob.Clears the springs fine, onlt problem is when I put 3yards of mulch in the bed the old springs tend to sag and the outter wheels tend to "rub" on the upper fender,I have used this truck for a"truck" hauling and pulling what ever I needed lol, I even went to 1-ton rotors on the front from a 71 C-30 all I did was put the rotor on and that was it, they have been on there for 2 years now and no problems.
