putting fluid in a engine hoist
Discussion in 'The Garage' started by adamforsythe, Jul 3, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    How do you put oil in a engine hoist?
    Adam
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Depends on the hydraulic unit. Some are non-refillable. The one on mine has a filler hole towards the bottom.
    If yours is refillable, you have to compressor the cylinder (to get all the air out) then filler up.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i found this old brass can with a finger trigger and straightskinny metal spout(straw) that comes out away from it at 90 degrees
    it is for some kind of oil but i use it for hoist cylinder filling, it works good, its not real big it only holds around 6 oz, but its just right
    find something like that at a yard sale or auction or soemwhere :D
    if i had a digicam id show you this one
  4. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    like this one prolly...
    i use one for oiling cylinders on compression tests on the boats.... handy little item...
  5. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    look closer...
    Both of my engine crane's hydraulic cylinders have a small rubber plug that looks like a button about 1/2 way up the cylinder..you pry it out and add the oil there...it was missing on one of them,someone put black electrical tape over the hole!..I tapped it to 1/8 " pipe and put a pipe plug in it...I used an nearly empty 90W gear oil bottle and the pointy spout to fill mine up--figured a little 90W wont hurt it,and it does seem to pump up faster and leak less with it in there... :crazy:
