putting in 52s ?
Discussion in 'The Garage' started by 4xrick, Feb 14, 2005.
  1. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    I am putting 52 inch stock rear springs in the front of my 75 blazer and wondering where people are putting there front mounts eather in front of the body mount half way inder the body mount to the front side and also how long of rear shackels are you running hole to hole?
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i put mine right under the bodymount, didnt have to move my rear shackle mout and have a good angle, the shackes are 6 inches hole to hole
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    As far as I know, most people are just removing the "L bracket" from behind the body mount and relocating it in front of the body mount... reattach the spring hanger with grade 8 locking hardware and you're set.
    shackle length depends on a few things. Seems like 6-7.25" is the norm though. Some people are moving their rear spring mounts also... and how much you do that will change how long them shackles need to be.
    j
  4. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    so you are running the stock rear shackels? do you have any problems with the springs touching the frame i have heard that if you run the stock rear shackels.
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    with stock stuff they are gonna hit the frame... ya gotta have longer ones. How long depends on the springs, hanger location etc.
    j
  6. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    ya im thinking i am going to run the front mounts with the l bracket on the front of the body mount. and shouls be able to run the rear shackels srtaight and at 7 inc hole to hole.
  7. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    anyone else have any opinions?
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    do a search on the subject, its been batted around by the guys that have done it. Im making a leap of faith with 7.25" hole-to-hole shackles for my 52s...
    j
  9. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    52" front swap. front mounts forward 4" just swap rh mount to left and and same for other side body mount stay in the same spot. first pic is with rear hangers in stock spot. 7.25 shackle, shackle angle sucks! 2nd pics is rear hanger moved about 3" used old front holes for new rear holes. angle is better:D 3rd pic is with adding 2 leaves,pulling the overload.
