putting in a tach
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jun 1, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    finally got me one
    just wondering what to search for if anyone has done a write up on how they installed it...save me some wire hunting time
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    its pretty easy... you hook the tach feed wire from your tach onto the single wire that runs into the distributor..mine's green... then you run one to the fuse panel... slip it over the fuse for the lights and push the fuse in on top of it... and then ground
  3. dyeager535
    26,979
    You can also just go to the wrecking yard and cut an accessory plug off the fuse panel (such as for power windows) and solder it to the 12V ignition lead for the tach.
    Then it plugs in the fuse panel.
  4. tecton
    Dec 1, 2002
    1,553
    WV
    having trouble finding the wire that comes out of the distributor
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    its ore of a pin, not a wire. its right next to the hot lead for the coil. that should be the only wire goign into your distributor now.
    Grant
  6. tecton
    Dec 1, 2002
    1,553
    WV
    my distributor has a little port bay on the driver side...one bay says "TACH" the other says "BAT" then above that it says "o+ GRD B-"
    is that it?
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep, plug it into the one that says TACH /forums/images/graemlins/thumb.gif
  8. tecton
    Dec 1, 2002
    1,553
    WV
    lol
    no plug...cant just cram the wire up in there
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    there should be a male end of a connection coming out of that spot where you connect the female end onto it.
  10. tecton
    Dec 1, 2002
    1,553
    WV
    there isnt
    its just an empty plug....ill flip though LMC and see if i can find it
  11. tecton
    Dec 1, 2002
    1,553
    WV
    ok
    if you have the new LMC
    look on page 81 of that flame thrower distributor
    the black box on the left of the picture with the ltitle nub coming out of it...thats what im talking about
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If you look at that same page in lmc, the pic of the dist all put together, it shows the wiring coming from the dist up to the black nub your talking about, right there is where the tach is supposed to plug into /forums/images/graemlins/thumb.gif
