Putting lug bolts in-new rotors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Mar 31, 2002.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    What is the best way to put in new lug studs? I arleady got the rotor off and am putting on new rotors and wheel bearings. 89 k-5 4x4 with manual hubs and stock brakes.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The best way is to use a press, but if you dont have one you can just use a hammer.
  3. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    man its so easy, set em in as far as they will go by hand, and use a long bolt as a punch, and beat em in with a hammer..you'll know when they bottom out cuz the bolt will bounce out of your hand..
    mike
  4. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    If you have a impact gun, take an open lug nut with a flat surface(or washers) and pull the studs through. Just spray a little wd-40 on em first.
