putting vortech heads on a tbi motor
Discussion in 'The Garage' started by supersize75k5, Oct 1, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    what im working on is a tbi motor, low miles, but a cracked head is in the picture,
    since the heads hae to come off anyways, does anyone sell vortech or perfomance tbi heads to bolt right back in, I dont want to have to change or purchase a new intake.
    motor is a 350, and summi was no help.
    Just would rather put something better in, the rig is used just for towing/ shop truck etc.
    :ears:
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If you go with a Vortec intake you will have to change your intake. You will need TBI heads or can use older heads, just have to elongate the center two holes on the intake.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    you can put Vortec heads on a TBI motor, It will raise compression about .7 or so, and you';ll need this: GMPP intake manifold
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Not only will you need a new intake, because no older intake will work, but you will need a new chip burned for the different timing/airflow curves.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    first off, Vortech doesnt make heads, they make superchargers.
    as for the GMPP intake dont waste your money, unless you have to pass emissions with a visual check, or a verified functioning EGR valve.
    you'll get much better performance out of a standard Vortec intake with a adapter for the TBI. cable routing could get interesting, but i would assume you can handle a little fab work.
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Or get a marine TBI intake like I did.
  7. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    well this is for a friends truck and I wanted to do it in 1 day and keep the price below 800.00
    looks like remanufactured heads are what I will go with, thanks guys!
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    details please...
