putty to seal on firewall?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, May 12, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Did my heater core today, and broke the seal of the putty on the firewall, and can't really form it back...where can I get this stuff? I tried Lowes, but they only have stuff not recommended for plastic...any ideas?
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I got mine from NAPA. Comes on a roll and looks like Tar.
    Can't find the receipt so I can't help you with the part #.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thanks, that wat I needed
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Also, RV dealer &/or a good hardware store might have something called Cool Seal (i think that's the name). Comes in black or white. Works good for such things.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've also heard it referred to as body putty. /forums/images/icons/cool.gif
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Are you reffering to (NAPA) butyl tape, normally used to seal windshields? I keep a roll of it around to fix/seal most anything that's clean. Another thing to look at is rain-gutter caulking. It never really hardens or sets.
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    That roll of butyl stuff or whatever its called was like $25. I ended up buying some Window-Weld, the stuff that glues the window in the sash. It cost $15, but I'll probably need it again.
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Can someone clue me in to what the putty does? I read 'seal the firewall.' From what? Heat?
    I don't get it.
    -- Mike
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's used to seal gaps/cracks in the fire wall to keep hot air and fumes from passing to the cabin area. It's also sometimes used as a sort of "form your own" grommet around tubes and stuff to keep them from vibrating/chafing/cracking.
