PWR Steering pump?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jmpd, Jun 29, 2000.
  1. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    How do you get the pulley off the steering pump? Do I need a Puller? If so what kind. There is a 7 point bolt behind the pulley and I can't get to it. The motor is a complete 350 TPI from an IROC, with all the serpintine drive system.
    Also 2 of the 7 point bolts have sort of stripped, I might be able to use a allen wrench, but will take suggestions.
    I'm in the middle of the pulling/rebuild/cleaning phase
    Michael
  2. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I tore the pulley off of my p/s pump a while back. I screwed it up. I found out the hard way that you have to take the back plate off some how first. Then there is just a little c-clip on the inside that holds the pulley shaft in place, pop that off and the pulley comes right out. I didnt know this, I thought it was just pressed in or something. So I took the nut off the front, threaded on a slide hammer, and went to town. The pulley came out all right, after killing the c-clip. So don't try that method, heheh.
    Good luck !
