Python 1000 ESP pre-stage alert problems!!!
Discussion in 'Audio' started by AntAZBlaz, Jan 24, 2003.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    I know it’s been a long time but I need some help bad.
    I have what I believe to be a Python 1500 alarm system installed on my 86 Blazer. I am having intermittent problems with the pre-stage alert (the beep beep noise) going off only in front of my dorm room building. Is there any way to turn off the pre-stage sounds and leave the alarm sound still connected?
    Equipment list.
    1) Python alarm
    2) Motion detector
    3) Back up battery
    4) Pager unit
    Here is the background information the alarm has been installed for about three years now. The shop that originally installed the alarm is one that I will never go to again because.
    1) I asked for them to attach a back up battery to the alarm, they found it convenient to attach to my accelerator. As I was leaving the parking lot I pushed on the gas and as I headed toward the street. I then pressed on the brake the Blazer kept moving good thing I had the sense to stick my foot behind the gas pedal, and lifted up on it to take the tension off or I could have been in an accident.
    2) I asked them to install a motion detector somewhere it would be able to detect movement in the rear cargo area and they placed it inside my consol, which was cool. The bad part was that I had left super glue on my consol from a project that I was working on and never took it out from weeks before I dropped the Blazer off at the alarm shop. Well come to find that the motion detector was glued to part of the consol and it appears that they used my glue and forgot to put the cap back on because the container of super glue leaked and was glued to the consol when I picked it up.
    3) I specifically asked them to hide the brain of the alarm some where inconspicuous and that I wanted it secured to something because I off road the vehicle and I didn’t want it getting tossed around. I even offered to pay the extra money if it was necessary. A week after the install was done I noticed the brain of the alarm hanging down near the steering column attached to nothing.
    Since then I have rewired it myself but I do not understand what the wires are for I just soldered on jumpers and rerouted everything the way that I wanted it. Well lately when I park in front of my dorm room intermittently the pre-stage alert will go off continuously for hours on end without actually setting the alarm off.
    When I park the truck in other areas this never happens. The stranger part is that I usually park my truck near the same space and have been doing so for a few years now and this has just recently become a problem.
    Well the cops were called out because my truck was waking up people and I explained to him that there is nothing wrong with the alarm because it only happens in this certain area and only at certain times. He told me that my truck could be towed if the alarm continues to emit it’s pre-stage sound because it is disturbing everybody. Mind you I have a parking decal that is only good for certain areas around my building and I’m try to leave it in the section that is well lit. I left it in the sections where it is not well lit and I had a 2meter radio stolen out of it $$$$ L L L and a friend of mine just had his jeep stolen earlier this week.
    So the best thing I could do is just eliminate the pre-stage alert, if possible. And just let the alarm blast off when it reaches that point to completely set off the alarm. Since the alarm never actually goes off unless it should.
    As a side note not to important can you also tell me how to wire the AUX button to roll down the rear window? Not to important but it would be nice to have as an option.
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Re: Python 1500 pre-stage alert problems!!!
    2 ways to go. One disconect the pre-stage completely or 2 put it on a toggle switch.
    The alarm should have a shock sensor on it that has 4 wires coming from the alarm. red, blk, blu, grn
    The green and blu are zone triggers. I want to say off my head that the grn is the pre stage. Cut the green wire and try and set of the prestage. If it only does full alarm then you are good to go. Wire this into a toggle and now you have a way to turn the prestage on and off. If it only does prestage then reattach the grn and do the same with the blu wire.
    As far as the window roll down. The 1500 has a red/wht wire coming off the main harness attach this to a relay on pole 86 attach 12volt constant to poles 30 and 85 then attach pole 87 to the down side of your rear window switch. Confirm that the rear window switch is a switched 12 volt. (i am alsmost sure it is). If it is a switched ground the change pole 30 on the relay to ground. This will let you roll the window down by pressing the aux button for 2.5sec or more. The window will stop going down as soon as you release the button. MAKE SURE and fuse the 12volt wires going into the relay also /forums/images/graemlins/tongue.gif
    So if this is a 1500 you do have the remote start option hooked up correct /forums/images/graemlins/thumb.gif
  3. AntAZBlaz
    273
    Mesa AZ
    Hey
    That was exactly the kind of information I was looking for. But I have a slight change I found out this morning that the model that I have is the Python 1000 ESP. I hope the color-coding is the same if you can just shoot me a message and let me know. Once again thanks for the reply.
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Same alarm as the 1500 just without the remote start /forums/images/graemlins/smirk.gif Colors are all the same, still haven't double checked but almost sure on the grn blu situation.
  5. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Oh almost forgot to put in a prop for my shop /forums/images/graemlins/ignore.gif
    Next time you need any audio advice or products feel free to shoot me an email. I would have sold you that alarm for 50.00 and I bet you paid alot more for it and still ended up doing the install it sounds like.
