Q' about 14FF hub bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan B., Jan 16, 2003.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Q\' about 14FF hub bolts
    So when i got my 14FF the axles weren't bolted into the axle and it didn't come with the bolts that attach the axle shafts to the hubs.
    Is this a pick and pull item?
    OR is it cool to go to OSH and pick up some Grade 8 bolts for that?
    I figured some grade 8's as long as they go into the threads in the hubs 1.5 times the fastener diamater it should be good. /forums/images/graemlins/cool.gif
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Re: Q\' about 14FF hub bolts
    The factory bolts are grade 8...so I don't see a prob with just getting some replacement grade 8's and calling it good.
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They're a standard thread that you can find at the hardware store. Mine are cad plated grade 8. /forums/images/graemlins/cool.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get 1 1/4" long, not 1 1/2" long because if you get the longer ones, they will bottom out and not hold the shafts in place unless you stack washers between them. The 1 1/4" long ones are the perfect length to seat the shafts completely and torque them properly. /forums/images/graemlins/thumb.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Keep this in mind Ryan, the factory bolts have a built in washered head that have a serrated underside to them to help keep them from backing off. You can use a standard grade 8 bolt of the correct length but you should use lock washers if you do this to keep them from backing out. If it were me I would be hitting up the local PNP for the correct ones or go to the dealer and get new ones.
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Right... i was thinking a lock washer too. That was about to be my next question. /forums/images/graemlins/thumb.gif
    Thanks for the info everybody..
    I think i'll go to pick and pull and pocket my bolts for the $2 admission price back! /forums/images/graemlins/thumb.gif
    How about some loctite? Or Just torque em and thats good?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that your lock washers are also grade 8. The lower grade ones aren't hard enough to bite into the grade 8 bolt. /forums/images/graemlins/shocked.gif
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ace hardware will have what your looking for...
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That's what I do. /forums/images/graemlins/cool.gif
    I go looking for somethig and if I don't I never come out empty, I fill my pockets with bolts nuts relays anything that is worth more than the 2 bucks I paid to go in.
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    just a thought, could they be safety wired? i don't see why not. talk about overkill. /forums/images/graemlins/thumb.gif /forums/images/graemlins/cool.gif
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Just bring it over Ryan, I'll weld the bolts to the flange for ya! They'll NEVER back out. /forums/images/graemlins/rotfl.gif
