Q about 84 c-10 trans crossemember
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Dec 19, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    84 c-10 with three speed saginaw manual, ]
    the trans crossmember under tail of trans, this would be identical to th350 one right ? it sure looks like its the same
    wanted to make sure on that
    those of you in the know know that the older trucks used to have rear engine crossmember and mounts for the old iron bellhousings, but they went to aluminum bellhousing and did away with rear engine mounts in 72
    so thats why i was checking
    thanks
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have swapped out a 1982 C-10 3-speed manual for a TH-350 set up and the crossmemeber was the same as was the driveshaft length .
    It was the tranny cross memeber that went on the out side of the drivers side frame rail and the passenger side connected to the upper rail and the bottom rail like the 1975 and loder stuff did .
    Good luck , Tom
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep driver side of the x member wraps outside of frame rail, pass side sits inside like old style does
    thanks
