q-jet cfm?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Feb 13, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    just curious with all of this q-jet talk, but how many cfms dose a q-jet have?
    No, thats not a dent in my body. I call it my armor.
  2. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    There were a few odd balls, but generally they came in either 750 cfm, or 795 cfm (which is usually rounded to 800). The neat thing about them is they automaticly adjust their airflow to match you engine, so you can put a 750 cfm Q-jet on a 6 cylinder and it will only flow what the motor can handle, just FYI [​IMG].
    <font color=purple>Jeff427</font color=purple>
    <a target="_blank" href=http://lyonsdesign.bizhosting.com>Lyons Design</a>
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I think Jeff's got it right.....from what I've been able to learn, it seems like the CFM is achieved by simply re-jetting. There are no signinficant changes in the base casting or throttle bores themselves. The only exception might be the 850CFM....but I don't know for sure.
    Here's a link on DYeager's site that will help you determine the 750's from the 800's:
    See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38
  4. dyeager535
    26,975
    CFM is actually changed by the castings. It's the fuel bowl casting (the center of the 3 pieces) that is different between 750 and 800's. Primary CFM difference is *roughly* 250 vs 300CFM for the 750 vs 800 CFM carbs.
    Most carbs from the 70's on, perhaps even earlier, were limited on the secondary side, secondary air valve shaft has a tang on the passenger side, for around 500-600CFM. Cut it.
    Nice Link! : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Yep....I "baited you" to come out and answer on this one! [​IMG]
    I bookmarked your site a while ago, and I go to it often. I'll admit I don't understand everything that's there yet.
    It's hard when you're first learning because even the "best" information can simply be "too much, too soon". Once I get a better base of knowledge and I go back to re-read that stuff.....it suddenly makes a lot more sense!!!
    Thanks for going to all that trouble to put the info there.....I know it's going to help me a lot in the future.
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
