Q-Jet Idle Adjustment
Discussion in 'The Garage' started by TrcksR4ME, Aug 29, 2003.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I did a search and could not find anything on this particular problem. My idle is at about 1300rpm, and the adjustment screw that pushes on the throttle linkage isn't even touching. The linkage is stopped by something else before it comes back and hit the screw. So are there other ways to adjust the idle? This is a used carb that I just put on and maybe it will need work but I wanna try and getting it going for the time being. TIA
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    The bushings in the throttle shaft might be worn and causing air to be sucked in past the throttle bore. Q-Jet bushings
    Just a thought. I am sure one of the members here can tell you for sure. /forums/images/graemlins/thumb.gif
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I found another screw on the pass side of the carb and was able to get the idle down, easy enough /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,979
    If a screw on the passenger side made a difference, the choke is messed up. That's idle speed adjustment for the choke.
  5. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    /forums/images/graemlins/thinking.gif The choke might need adjusting then too.
    I just know that that the screw on the pass side was bumping up the idle because the throttle linkage would not even touch the screw on the drivers side, if that makes any sense.
    Does this mean that the choke will raise the idle when you first start it up and once it was warmed up the idle drops back down to normal? I noticed the idle dropped some after it warmed up, but I dunno anything about these carbs. I am just guessing
