Q-Jet on an Edelbrock intake
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aksidentproan, Sep 25, 2002.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I'm going to start my truck tonight and I'm going to use the stock Q-Jet on top of the edelbrock performer intake manifold. Will it bolt right on or do I need an adapter? Any Idea where I can get this adapter if I need one? Any other suggestions(problems you've run into) on starting a motor up for the first time? Thanks.
    Evan
  2. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Yes, you will need an adapter because the edelbrock performer carbs are squarebore (primaries/secondaries are basically the same size) and the q-jet is a spreadbore carb (big ol secondaries). I'm pretty sure most auto parts stores that sell edelbrock stuff have the adapter plates. Just looked in Jegs and they have one from Moroso for $54, but I thought I've seen other brands for much less.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    It depends on the Performer intake!! I have a performer intake and my Q-jet bolts right to it no adapter needed!
  4. ak7
    ak7 Registered Member
    Feb 15, 2002
    57
    Hayward, CA
    I'm the same as Burt. I have the rochester qjet with the edelbrock performer intake and it bolts right on. No adapter needed. The only problem you may run into is running the 14" air cleaner on the carb with an HEI distributor. My air cleaner buts right up to the HEI cables and I could squeeze it in there but I recommend getting the 2" spacer for the air cleaner.
    ak7
  5. mdstmpr
    mdstmpr Registered Member
    Apr 21, 2002
    41
    Riverside,Ca
    I had to get a carb adaptor from auto zone, i think it was like twenty dollars, then had to get 2- 4" bolts for the front of the carb.spent twice the time running around then installing. if you have four holes on the top of your intake you should be good to go.
  6. skyblazer
    Oct 1, 2000
    209
    Houston, TX
    Oops, forgot about the fact that Edelbrock made spreadbore style intakes...Just assumed you had the squarebore style since you were switching over to the q-jet.
  7. aksidentproan
    Dec 8, 2001
    477
    Maryland
    Mine bolted right up without a problem. Then the engine fired right up. What a sweet sound of a built 350. I guess I'm back to getting niose violation tickets again. Thanks Guys.
    Evan
