Q-Jet tuning
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Oct 6, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've never been much of a great carb-tuner, usually I'm content just with keeping the thing running. I'm tired of running a bit rich though, and don't have anything else on the schedule for tomorrow, so anyone got some helpful words of wisdom for undertaking this task, and doing it right? TIA for any input[​IMG]
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Hook up a vacuum guage...and adjust your mixture for the highest vacuum reading. That should put you very close to ideal for your motor.
    Rene
  3. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds easy enough[​IMG] Maybe I can set a fuel mileage record on next weekend's road trip across the state.
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Is it just rich at idle?
    Rene
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    As far as I can tell it's running a bit rich all around - there's been lots of soot in the tailpipes for the last couple of weeks, and it's been lacking a bit in throttle response.
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Adjusting idle mixture will only affect the idle circuit (obviously)
    Float levels may be off, something could be gummed up and not moving properly...
    How's the rest of the 'consumables'? Plugs, wires, cap, rotor? If everything else is tip-top you might want to take a closer look at the Q-jet.
    If you take the cap and rotor off check the mechanical advance for stickiness. Mine was all gummed up, cleaned it up for free and gained quite a bit of performance.
    Rene
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Could be - the thing's probably due for a complete going over. Plugs and wires are new, Cap and rotor have about 2,000 on them. I never thought of the advance - I'll check it out, and try and clean up the carb some and see if that helps. Thanks a bunch[​IMG]
