q-jet won't idle.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 Shortbox, May 6, 2003.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    q-jet won\'t idle.
    I just had a quadrajet rebuilt and through it on and it won't idle. It will rev to about 2000 and then slowly make its way down to about 800 and then it revs back up. I will admit I don't know much about carbs so any info will help. I don't want to just start turning screws and completely screw it up. Also I am running a healty cam and wondered if vacum has anything to do with it. Thanks guys.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: q-jet won\'t idle.
    with the air cleaner off start it up and cup your hands over the top of it if it Reeves up you have a vacuum leak if it dies you don't and need to look for other problems
  3. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    I'll try that first. Thanks for the info.
  4. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    Sometimes a rebuilt one will come with the mixture screws turned just about all the way out, like 12 turns, causing them to not want to idle at all, but rev up good. I would say a good starting point is to have them out about 1 1/2 turns each.
