q-jet
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Jul 25, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i got a renanufactures quadrajet from oreilly's and its leeking gas out of the passenger side by the rear 2 butterflies. any ideas. the truck has only been cranked for a total of maybe 10 minutes since this was put on. do you think this will seal up once it gets good and hot or is something wrong. it came with three gaskets. 1 metal, 1 fiber, i neoprene? with hard plastic spacers for the screws. i used the neoprene lokking one. the fiber on was two wide at one part. anyone have any ideas.
    thanbks in advance
    nathan
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If you just got the carb and it is leaking, take it back and have them try again.
  3. Scorpion
    Scorpion Registered Member
    Jun 5, 2002
    60
    Denver, Colorado
    When trying to get one for a friends Camaro, we had the same problem 12 times! It's not an exageration, each time we got one, we bolted it on, and then sprayed starter fluid at the base of the carb. If the RMP increases, you have a carb with a warped plate. Take it back. Turns out that when they are remanufactured, they pull the old one apart and replace all of the internals with new stuff. What they don't do is check the plate for warpage. It's crap but it's how it goes.
    I on the other hand, got one off of a van at a wrecking yard for my Blazer and first time was a charm. True luck I guess...
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i will take it back like all have suggested. i was warned about this. i just couldnt get my wife to let me the spend the extra dougjh for an edelbrock. thanks for the help
    nathan
  5. Scorpion
    Jun 5, 2002
    60
    Denver, Colorado
    Just and FYI, I've had friends that have purchased eldebrock carbs and have gone back to the quadrajet. It's a great carb for all around driving and highly rated for 4x4's. There is new technology that is pretty impressive but the quadrajet has withstood the test of time and it has been my experience that reliability is worth something. Good luck!
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i'm gonna keep the q jet. thanks for the advice. i agree ther was a reason they used it so long. i dont rock climb anyway.
    thanks
    nathan
