Q jets or edelbrock, holley or other. Carb problems and questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by speed_deed, Mar 5, 2002.
  1. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I have 2 k5s with 2 305's and 2 q-jets. I bought the '85 6 years ago and have always been fighting with the carb. I bought my '84 in january and the everything is fine with it execept the front drivers side (alot of damage fender,hood and grille/radiator mount are screwed for good) makeing it illegal to drive so I figure I will switch the 84's carb to the 85 to get it running better for daily driving and take the 85's carb inside clean it up adjust it then put it on the '84 and make the final adjustments. I noticed they weren't quite the same when I opened both hoods but proceeded to take them off. When I tried to put the '84's on the '85's i ran into a problem and they are way different and wont interchange. Question is, 'What should I do?' I know all I have to do is adjust the 85's and put it on but i dont want to mess with it much longer and am getting sick of it. i am thinking of putting the '84's back on the '84 and just getting a new carb for the '85. My dad has told me forever and, I am seeing myself that the carbs from this time period were really good or really bad. Looks like i got a really good one and a really bad one. Anyway I am wondering what you would do. Would you rebuild the '85's q-jet get a edelbrock, holley or something else. I have an old carter (mopar) that I could make work for the 305 but I wouldn't want to put an old 440/6 carter carb on there. My budget is so tight it is cutting circulation off to parts of my body. Rebuild would be cheaper but new would be easier. I'll get some pictures of the carbs. It would probably make things alot easier for you guys to help me if I did so, I will. What would you do?
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I personally would rebuild your '85 carb. Yeah, it is more effort than a new one and may not even solve the problems, but it is the first step I would take. I have an 85 and didn't realize that the 84 and 85 models were different. Some people will probably also tell you to just ditch the carb and go with TBI. But, as you are on a budget, that isn't really practical. Not too mention, I spent some time this weekend on STEEP angles and never had a problem with the carb. One time I was at a 62 degree incline and 0 degree roll and it did fine (while they were getting the winch ready to pull me up out of the hole). The other time I was at a 55 degree incline with an 18 degree roll (not a good position in a large K5, let me tell you) and it never even hinted of cutting out.
    I would stick with your 85 carb and try a rebuild first. If that doesn't work, then I would re-evaluate.
  3. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    Thanks alot. Anyone else have an opinion?
  4. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Sell the car and invest the money into the K5.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Get Doug Roe's book on Rochester Carbs and rebuild it yourself. The book is around $20 and rebuild kits are cheep.
  6. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I had alot of problems with my 85 q-jet, it had some kind of half-a$$ed computer hookup from the factory. Some kind of early eprom I think, so I put an older "non-electric" one on and it works great.
  7. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    I am talking about my k5's. /forums/images/icons/laugh.gif /forums/images/icons/wink.gif
    Thanks guys I did go to autozone lastnight and bought a rebuild kit. It only cost $19.99. Not much at all. I am gonna rebuild it later today.
