Q on Changin Trans Case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scooby, Feb 19, 2002.
  1. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    changin from a 208 to a 205 will it hook up to my TH350 tranny? and is there any diff in my front shaft? (get what im tryin to say?)
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you currently have a TH350/208 and you want to put the 205 behind it instead you will need the TH350/205 adapter. You also need to make sure the 205 has 27 spline input. If it has 10 spline input you can convert it to 27 spline. You will also need to do driveshaft mods.
  3. scooby
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    What type of mod will I have to do to the drive shaft?
    plz be specific on what type of mod for the drive shaft cause I need to know cause im gettin the case for my blazer 2marrow and puttin it on 2marrow so i can go back to off roadin on the weekends
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I believe you will need to lengthen the rear shaft and shorten the front shaft.
