Qjet choke ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77fixer, Sep 23, 2004.
  1. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Can I swap an electric choke onto an older carb that came with the manifold heated choke or would I be better off just rebuilding a carb that came with the electric. I am helping someone put a 4.3 in to a scout and I haven't seen the manifold yet, but I am assuming it has no provision for the heated coil.
  2. dyeager535
    26,979
    Some you can, some you can't. My dad had one that he was going to retrofit, and the peices weren't interchangeable, the carb casting was slightly different.
    However, some people on here have had success swapping the choke styles, so apparently it is hit or miss.
  3. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Some fit others you need to swap the choke housing.
  4. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
  5. dyeager535
    26,979
    No, the casting of the carb itself was different where the choke housing sat for electric variants...the three "legs" don't match up on some of them, they were shorter or something, the linkage couldn't be made to work because of it.
    Again, this was only on one carb, it could be rare for all I know. I had really good luck with my mechanical choke, so I never felt the need to change.
  6. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    /forums/images/graemlins/doah.gif I haven't ran into that yet.
  7. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    Thanks guys. I'll wait to see the manifold and then see about switching the choke.
    Brett
