Qjet ??, electric choke a must have?
Discussion in 'The Garage' started by gjk5, Feb 19, 2006.
  1. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I am getting rid of the Edelbrock Performer on my '72 this week, Auto Zone says they only have a 4MV manual choke and cannot get an electric for it (??). Is this a big deal? I have the manual choke dash in my truck so it will be factory, has anyone else living at a decent altitude (4,700) had any problems or am I better off looking for an electric choke model (so far only one I could find was at Napa and was double the $$)
    Should this carb be good to go out of the box (other than idle mix screw adjustments), or will it need to be rejetted or anything?
    Also, it is a Champion rebuilt Rochester, anyone ever use one of these?
    Anything else I should be prepared for going back to the Qjet?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    http://www.carburetion.com/quadrajet.asp
    sells divorced electric choke modules
    I got a Holley rebuilt Qjet thru Autozone and didnt touch a thing other than idle speed, because you are at altitute you probably will have to tune for that, but should be ok otherwise
  3. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Just searched that site, they have a pictures page of chokes but no results returned for 4mv choke.
  4. mechted
    Oct 19, 2003
    765
    Granbury, TX
    4MV is the "divorced choke" you should have a flat spot on the manifold on the pass side of the carb, with a hole for a small bolt. that is where that module mounts
  5. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I'll have to check around, I just checked pain old chokes on their site and no products came up as available, maybe I'm missing something.
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You can get the divorced choke kit from Summit Racing.
  7. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I had a manual choke on my '64 pickup, and I never used it.
    About the best operating choke setup I've had is the divorsed choke.
  8. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I recently rebuilt one of my many qjets, decided to completely delete the chock stuff (it was a manual choke model). I even got rid of the linkages that keep the secondaries from opening.. only takes 3 minutes of idling for it to run fine here (but its never below 65)
  9. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I checked. Summit only has them for the edelbrock performer qjets and the site says it's designed to fit a performer intake manifold.
  10. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Dave I'm going to the salvage yard tomorrow, I'll see if I can find the stock divorced choke, the only difference will be the rod length. The housing and bi-metal coil are the same.
  11. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    just put a rebuilt 305 quadrajet electric choke on a 78 pontiac catalina with a factory chev 350( thank god canada had chev engines in pontiacs)
    anyways, it runs AWSOME, synthetic fluid for years. 100k and grandma owned.garage kept its whole life
