QJEt pics please
Discussion in 'The Garage' started by 84gmcjimmy, Feb 12, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Can everyone with a camera and a q-jet carb snap some pictures of the choke side of the carb? I want to know if mine is hooked up correctly from the rebuild last winter. As its not running or starting properly.
    Thanks, I appreciate and pictures I can get :)
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  3. dyeager535
    26,979
    Just take the air cleaner off of it in the morning, and see how it reacts as you go from startup to warm engine...
    Cold, kick throttle twice. Choke plate should snap shut. Start engine, the choke plate should crack open slightly, then gradually open until the blades are vertical. This could take anywhere from approx. 5-10 minutes.
    If it doesn't operate like that, no it's not right. They aren't very complex, but they are fairly difficult to get setup right.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks Dorian and Jiminy.
    Once its running again I will check that out.
  5. dyeager535
    26,979
    The first part you test without it started, so as long as the throttle is hooked up, you can test that.
    You'll have a more difficult time starting anyways if that portion isn't right.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    The difficulty in getting the choke, vacuum break, etc. all set up right is that you really only get one chance a day to try out your changes. But start by making sure the choke is at least closing after a couple of throttle taps on a cold morning. You may need some cleaner to make sure nothing is sticking.
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Here is a pic, its off a '86 454 from california. Its not a very good angle but maybe you might make use of it. Dont pay attention to the vaccum lines though the PO had them all screwy. If you really need it I can take another pic at a better angle.
  8. wicked jester
    wicked jester 1/2 ton status
    Jan 8, 2004
    139
    CANADA
    Hope these may be of some use to you.
  9. wicked jester
    Jan 8, 2004
    139
    CANADA
    here are the rest of them, hope they work for you
