quad shocks up front or just two?
Discussion in 'The Garage' started by colbystephens, Jan 10, 2006.
you should run
  1. dual shocks up front.
    14 vote(s)
    22.2%
  2. single shocks up front.
    49 vote(s)
    77.8%
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i'm hoping to install new shocks tomorrow on my project - but i can't decide what to do. i've heard it recommended to just run single sets of shocks instead of duals on each side - but i don't know any reason for this. anyway, it'll be under a 6.2 in a k5. thanks.
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I don't know the benefits of running dual shocks, I do know that most K5's I have seen that wheel only have one shock per side.....
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    one shock per corner with the correct valving is the way to go performance wise unless you want the more shocks then teeth look
  4. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    depends on how much you like your kidneys. My brother has a 1973 bronco and had dual shocks on the back and greatly contributed to the truck living up to its name, that rear end was so stiff it would launch every time you hit a pothole or a speed bump. we took off one shock from each side and its been much easier to deal with as a DD. now if youre gonna be carrying alot of heavy cargo, i could see the twin shock setup, but even for off roading i think that stiff twin setup would be a negative characteristic. but im not an avid off roader so wait for someone with more experience to comment on that. Personally id invest in a set of good shocks and run them one shock per wheel.
  5. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    It really depends on how much unsprung weight you have. I have a D60 with 40x19 Boggers (160lb. each with rim), and it really helps to have dual Rancho 5000s on both front corners. I've had 35s on it and it was way to stiff.
    It will also help tons if you do long trail runs at speed (anything faster than running speed) where the shocks tend to overheat and fade. That's why racers run multi- or remote reservoir shocks.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    cool. i'll run single shocks. i just wondered because the stock setup was duals up front. i like the idea of spending less. thanks for saving me the cash.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if its a show truck, buy a new tower and run 3 on each tire:p: . these things were made back when shocks werent that great. with the technology now, 1 shock is far superior to dual shocks from the past.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    this is definitely not a show truck. first - the idea of that makes my stomach turn, and second, even if the idea of it didn't make me sick - just look at the pics of my rig on my webpage. :) it'll look a hell of a lot better than that when i'm done, but still - i hate show trucks. :D anyway, point taken. ;) thanks for the info on the difference in shock technology between now and then - hadn't really occurred to me since the idea of a shock is pretty basic..
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, I'd much rather have a nice shock (lets say, a $100/shock like the BBCS15) than two $50 shocks. If the valving is right and the shock is of good quality, you'll be fine. Dual shocks were used on factory rigs back in the day because shock tech pretty much sucked. Thanks to monster trucks and various kinds of racing, its a whole lot better now. For 99% of your trail rig drivers, one per wheel is plenty. If you like whoops and desert racing, two might last longer before they start to fade.
    j
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have tryed both set ups on my K5. I like dual the best but I do a lot of high speed and long distance desert driving. And they work better on washboard roads without fading..
    Single works great for trails. Just make sure to get a shock made for single shock applications. Dont just take off one of the dual shocks.
    Same for dual shocks. The factory dual shock set up used shocks with valving set up to ride good in a dual set up. Putting 2 shocks per corner that are designed to be run as a single set up will make dual shock trucks ride very rough.
  11. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I run duals because in mine the ride is better. Probably because I have cheap shocks, but that is the factory setup and I stayed with it after my lift.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Not too many run multiple shocks anymore. Only two exceptions I can think of. One is when they're running both a coil-over and a by-pass. The other is when stuff interfers with putting a large enough OD shock on the truck, but two smaller OD shocks will fit.
    Footnote; I've been reading that the H2 racing BitD has 3.0" front shock and their shock oil temps are so high that they're looking at going to a 4.0" OD shock body.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i run single $15 gabriels, they ride real good, considering its sfa
  14. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    im with you, im not building my rig to be a caddilac. if it wasnt for the fact that it will see the highway, i probably wouldnt run shocks period. cheap=on the trail vs. workin' overtime to afford expensive parts.
  15. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Single shocks, but run good ones - don't chintz.
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i thought this thread was dead 2 1/2 months ago.
  17. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    perhaps it was, but i was bored so i looked back. oh well,
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  19. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    4 shocks in the front=homoghey
