Quad Shocks, which one to remove?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dznutz70, Dec 26, 2001.
  1. Dznutz70
    Dznutz70 Registered Member
    May 18, 2001
    21
    San Ramon, Ca
    My 89 Blazer has the stock quad setup along with all stock suspension. I would like to make the ride a little softer till I lift it.
    I am under the impression that removing one shock on each side will help a lot. The shocks were on it when I bought it about a month ago. The front foremost shock it bigger then the second shock. Will removing one or the other hurt anything?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Wont hurt it. Remove the smaller shock. It will ride a little better this way.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Pull the forward shock. Look at the mounting point on the axle and you'll see why. If you really want to improve your ride quality, get the ORD greaseable bushings when you lift it.-Jim
    88 Silverado K5 5.7-700R-208-10 bolts-4.56-35in
    Procomp AT's- some ORD stuff & a CV driveshaft
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Pull the forward most shock. Your axle actually moves back during compression so the shock furthest to the rear will dampen better than the more vertical one.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just do like Steph and save yourself the time--drill a hole in the forward shock. Looks cool too!
    Tim
  6. Code3K5
    Code3K5 Registered Member
    Oct 9, 2009
    90
    Torrance, Ca
    pull the front... pull the rear :doah:
    which is it :haha:
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Oh my gawd!!!!!:yikes: Its Timmay....
    Back from the dead.
