quad to single
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Dec 15, 2001.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    When I install my lift, will I have to get another bracket to install a single shock? I have the factory quadl right now.
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I do believe that one of the shocks is in the position of the single shock. Probably the foremost one. Determine the single shock appropriate for tha application. Check at the dealership.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    When i did the 4:10 swap (housings and all) into my sub, it had the quads, the donor didn't. but the flanges on axles end were the same. Vehicle had 4 fairly new shocks, so what the heck! If frame is quad, axle dual, it seems the bolt is the big difference on the lower end.
    and.. based on what the donor had, i'd think the rearward shock was the 'factory' mount. Think the 'add on' was more forward/vertical mount' (or at least it seemed on mine...)
