Quadrajet Carb of a 1975 BBC
Discussion in 'Engine | Tranny | T-case' started by Klink K5, Mar 31, 2005.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Quadrajet Carb of a 1975 BBC (Good Carb)Update
    Carb is off a 1975 C-20 pickup 454 v-8 with a divorced choke witch will be included. Carb works great, bolt it on and go. Had a kit installed and float cause it was time. Updated to a larger cam and bought a holley for it or I would still be running it. It needs a good home, don't pass it up, I will not be useing it in the future, don't want it to go to waste. Includes Factory air cleaner. There it no kickdown bracket on it also cause the 454 was mated to a th400. $75.00+freight
  2. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    TTT, this carb needs a good home, too nice to let go to waste
  3. sean'schevy
    sean'schevy 1/2 ton status
    Aug 5, 2004
    149
    New Egypt, NJ
    any idea what the CFM is. thanks
  4. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    I believe on 454's are 800-850 cfm. If you are running it on a stock engine with a mild or stock cam, it will run just fine. I went to a pulling cam, high rise intake and double pump holley for truck pulling competition. Needed the MORE fuel route after the mods.
  5. sean'schevy
    Aug 5, 2004
    149
    New Egypt, NJ
    sent ya pm.
  6. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    TTT! you people are missing out on a good carb. Later Klink K5
  7. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    possable interest, shipping to 29349 :D
  9. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    will ship to ya at 90.00 complete deal, you won't regret it. Thanks, Klink :cool1:
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the two sizes were 750 and 800
    750 has larger annular rings in the primary bores, easy to tell from smaller annular ring in the 800 primaries
    just look down in it and see :D
    it could be either
