Quadrajet choke question
Discussion in 'The Garage' started by guido666, Nov 8, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Now that it is getting colder, when I start my truck it will crank but not start. If I tap the gas as I let off the key it will ROAR to life. Is this a problem with my choke? Should I maybe adjust it a little more open?
  2. dyeager535
    26,980
    Do you tap the gas before trying to start in the first place?
    The gas pedal HAS to be depressed for the choke to be set before starting.
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Yes, I do (if I remember), out of habit. So are you saying not to?
  4. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    No he is saying you have to. Before you even crank it over, tap the gas, or just give it one pump. This sets the choke. if you don't set the choke your gonna be cranking forever to get it to start.
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Ok, is it bad if you do it twice?
  6. BIG*RED
    Mar 14, 2003
    1,094
    Bad? no not really. I have a friend who has a '72 camero and he has to pump it 3 times before he starts it.
    its only "bad" on fuel injection..you don't want to pump the gas when you start a car that has fuel injection
  7. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Ok, so assuming that I am resetting the choke, or properly pushing the pedal before starting, any other ideas?
  8. BIG*RED
    Mar 14, 2003
    1,094
    no not really, its a carb. when thery are cold, they do this. I'm sure there might be a few things you could "tweek" but i'm not all that knowledgeable about carbs. maybe someone else will have some tips.
  9. dyeager535
    26,980
    No, just saying you need to.
    It is probably not adjusted quite right if it won't start like that.
    To test that it is working right, take off your air cleaner in the morning (or after it's sat for a very long time) look at the choke blade, and work the throttle from the carb. The choke blade should "snap" shut when you do this. If it doesn't, it will likely have some slack in it (not spring tension) which means it needs to be tightened up a hair.
    Gotta be careful when dealing with chokes though, all the choke linkage and what not is tied closely together, if one piece is not bent right, just tightening up the coil typically doesn't fix the problem, only shift it.
