Quadrajet Leaking Down
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockink5, May 15, 2006.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Started working on my Blazer again after sitting for about a year and half. The fuel system is trashed. Good California gas has taken it's toll on the rubber lines and carb:doah: . I've replaced all the lines, but the carb bowl refuse to stay full after sitting for about a week. The Carb is about 5 years old, I spent big money on it, and it works great when it's running. What could it be leaking from. I am not a carb expert, thats why I bought a new one. Any Ideas?:confused: It's a stock Q-jet on a 1985 Blazer
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    This might sound dumb but maybe it is evaportating
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well plugs are leaking . Disassemble , use appropriate epoxy to seal :thumb: Known to be common on our carbs .
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    There are 2 plugs on the bottom of the float bowl. It is common for them to leak. Pull the carb off the manifold and turn it over. You will see the plugs on the bottom of the bowl. Just put some epoxy in them. It usually seals them up.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Very common on a Q-Jet. Rebuild it and use a little JB Weld to seal it up
  6. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I was just living with this problem. Leaks down overnight. first startup is always a minute of cranking. Now I have something else to fix.
  7. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Thankx guys!
