Quadrajet model 7045738 ?
Discussion in 'The Garage' started by Nonesuch, Jan 27, 2004.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I have a 7045738 Rochester that I can't find a rebuild kit for. I have broke the model number down into this:
    70- Rochester
    45-1975
    7-
    3-Cadillac
    8- Automatic
    The 7 (emissions) is throwing me off. 2 indicates Federal and 5 indicates Cali. Why and where is this 7 coming from? Should I and can I just purchase a 7045238 rebuild kit since I don't need emissions or high altitude? Or were there items in the manufacturing process that may require me using the specific 7045738 kit?
    I am assuming that since I know the year of the carb and I know I don't want emissions that I can get away with the 7045238 kit. Any thoughts?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I bet you could get away with the "2". I wonder if the odd number is for a boat setup or a motorhome that they put a Caddy engine in? /forums/images/graemlins/thinking.gif
  3. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    This engine/carb definatly came out of a caddy car. I have seen some part numbers such as 7045193 in the books as well which make no sense either. Q-jet's definatley can be confusing when identifying. I will use the emmisions code "2" kit most likely. I just am looking for some 'expert' opinions. /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  4. dyeager535
    26,979
    Knowing carb kits, it will *probably* come with the right gaskets. If that carb is high altitude (only thing I can think of that "7" could denote that isn't covered in the decoders I looked at) then I'd suspect that the calibration of the carb is whats different, not the gaskets and all.
    CA models are *probably* the same way, but to be honest, as many of these carbs as I've had apart, very few are the same internally. (passages, gaskets, accelerator pump, etc)
    Carb kits suck, because all the ones I've ever purchased are not returnable once you open them, which is the only way you can compare the gaskets, which are the only real difference in the kits. (which usually come with twice as many gaskets as you need)
    Doesn't the auto parts store ask for the Q-jet ID numbers anyway?
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Those carb kits always seem to come with about 4 different airhorn gaskets plus a bunch of other stuff. I bet you would be OK.
  6. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    The knock off kits are cheap at $13 bucks. I will give the 7045238 kit a shot and if it works out I will by a name brand kit when the next rebuild is needed. I probably won't run this carb on the Cad 472 very long. I am eventually going to run propane on this motor.
