Quadrajet Ports
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74Chev, Dec 22, 2002.
  1. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    Just got done installing a quadrajet to replace my edelbrock carb, which was horrible offroad. It has been a while sine I messed with a q jet and need to know which port to hook the distributor vacuum advance to. The truck I pulled it off of had it (as you are facing the carb on the truck) on the very lower left, is this right? There is also a port on the right about halfway up the carb body, was this for the cold air block off on stock air cleaners? It has a cut off hose with a screw in it. Thanks for any help.
  2. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    sounds right to me.
  3. Ben Malinski
    Ben Malinski Guest
    Driver's side front port.
  4. 74Chev
    Sep 19, 2002
    102
    Oregon
    Now I am really confused. One reply says to keep in on the lower left, the other says drivers side. Which is it???
  5. dyeager535
    26,978
    Mine is on the drivers side front of the carb. EGR *typically* the small tube on the passenger side front. Both are "timed" thus some confusion, but I believe the ports use different size tubing. (although its close)
    Compare the tubing size for the vac advance to the one on the front of the carb, make sure its timed, and you should be good to go. I'm sure if we did a poll, we could find some year Q-jet that has the vac advance port sticking out of the air cleaner. (exagerration of course, but to point out that the Q-jet has many, many different port configurations)
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep, there are alot of variations over the years
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Any idea as to what year its from. Before '80, it should be on the right side, middle. 80 or 81 on up will have located in the lower left. /forums/images/graemlins/wink.gif
