quadrajet problems
Discussion in 'The Garage' started by buster boy, Aug 4, 2004.
  1. buster boy
    buster boy Registered Member
    Feb 2, 2004
    14
    canby,ore
    I have a 86,burb ,350ci goodwrench motor brand new 300 miles, the secondaries aren't opening,and i think the choke is sticking any help? /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/cool.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    if the choke is stuck it will not allow your secondaries to open. what model qjet are you running? (electric, hot air, thermstat, or manual choke?)
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    would that apply to a carter afb???i have two q jet to use if i need them. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  4. buster boy
    Feb 2, 2004
    14
    canby,ore
    electric choke, secondaries wont open,choke stuck?
  5. buster boy
    Feb 2, 2004
    14
    canby,ore
    need help on my quadrajet?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are you driving and getting on it and not hearing them , or revving it with the air cleaner off ? Mine you can hardly hear with the big air cleaner . This design carb only opens the secondaries as its needed on engine demand .
    Anyways , make sure you have 12 volts at the choke wire when ignition is on . Obviously look for any binding or bent linkage rods . Has anyone touched anything thinking it would help , like the adjustment for how much air will force them open ? /forums/images/graemlins/k5.gif
