Quadrajet question
Discussion in 'The Garage' started by BlahBlah, Apr 8, 2006.
  1. BlahBlah
    BlahBlah Registered Member
    Apr 13, 2005
    10
    Oregon
    Do they make a quadrajet with mechanical secondaries or are they all vacuum? I'm guessing that they are all vacuum. If so then is there a way to get rid of some of the lag when you go full throttle? I've got the Edlebrock performer on my motor now and love the throttle response, but even with the offroad kit even looking at a hill makes it stall. I'm putting a new motor in so maybe it would be worth it to buy a truck avenger. Gimme some ideas guys any help will be appreciated.
  2. Matstro
    Matstro Newbie
    Jan 26, 2006
    3
    Winnipeg, Manitoba, Canada
    If you have lag or bog when you tromp the throttle that means the seconderies arn't adjusted properly. The adjustment procedure is not complicated on a standard Rochester but I am not certain about the Edelbrock.
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if you're getting a secondary-bog, iirc, likely means that the secondary air doors are opening too fast.
