Quadrajet Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lazydog, Sep 22, 2002.
  1. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    How do the Secondary butterflies on top of the carb open. Is it vacuum or mechanial linkage. With the engine Off I pressed the gas pedal to the floor and they do not open.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the actual action of air being sucked through the secondaries at the higher rpm is usually what trips them open, they arent held shut by much pressure and that pressure(loaded spring up underneath on the shaft on pass side) is adjustable with the lockscrew up underneath and with the flat blade screw set into the shaft end begind the link on shaft end
