quadrajet + TPS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike reeh, Feb 11, 2007.
  1. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    who's got a TPS working with their quadrajet? any one have stories/setups to AVOID or stories/setups of stuff that works real well and/or is cheap and/or uses GM parts?? thanks!
    mike
  2. dyeager535
    26,982
    191
    Interesting project. What praytell do you need TPS on a carb for? :)
    It should be FAIRLY simple, but time consuming, to set up a bracket that would allow a later TPI TPS to work, or I guess you could find one of the CCC TPS', and try to mount it some way that it would get the right travel.
    TPI (and TBI I assume) use an arm that engages the throttle bracket, while the CCC ones have a "remote" plunger that was underneath the accelerator pump arm.
  3. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    I will be setting one up shortly for use with the 4l80e. I plan on using TCI's. Summit has them for $199.
