quadrajet tuning
Discussion in 'The Garage' started by mudhog, Dec 28, 2002.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ok i know on the edelbrocks you turn the 2 screws in all the way then back them out 1 and a half turns and you are close but what about a true quadrajet? do you turn them out 1 and a half turns as well to be close?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used to start be turning them out 4 turns. Then I would screw them in untill the rpm's started to drop, then back them out a hair. It seemed to work for me. Its only the idle circuit anyway.
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    that should work fine to get it started. did you get a new one or a use one? you'll definately love it off road
  4. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    You should have 2-3 turns average but it depends on the tune of the engine. if you have a performance cam you'll prolly have to drill out the idle orafices to .095 (5/32 close nuff) before you can get it to idle correctly. Be warned you can forget about passing emissions test if you do this... i never had to worry about that stuff /forums/images/graemlins/pimp1.gif
  5. ericguy320
    ericguy320 Registered Member
    Dec 28, 2002
    23
    NC
    i screw in all the way and out 2 and a half and leave it
