quadrajet??
Discussion in 'The Garage' started by smprider112, Aug 22, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Ok, so Im ready to ditch my edelbrake carb for a real one!! either gonna use the Pro-jection I have access too, if I can find a wiring harness or fix the one it has! or get a quadrajet, problem is I have been lookin on ebay for em, but there seems to be quite a few different ones out there...so my question is for a 77 w/350 what kind will fit?? or does it not really make a diff?? I plan on buying one and having it rebuilt so the condition isnt too important too me...But I dont know which years are compatible or not?? I see some manual choke, hotair and elect...I assume I use elect since my edelbrock has elect choke /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif anyways all help appreciated!! /forums/images/graemlins/thumb.gif
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    You should be able to get about any q-jet and take it to a shop and tell them what engine you have and HP etc and have them build it for you. I just took one off a 350 and put it on my 402BB and it actually works pretty damn good. I had tried two other before this one and they both worked ok, this one has been the best so far. I have about $50 into my q-jet experimentation at this point. They all have been better than the Carter chrome job I had before, but have had float level issues on bumpy up hill terrain with a lot of bouncin around.
    Its not rocket science when it comes down to it. I just have done trial and error and figured out how to work on them in the process. Someday when I can afford it I will get an Edelbrock Q-Jet /forums/images/graemlins/waytogo.gif
  3. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    what about electric choke an all the other kinds? which one would be ideal? is it hard to hook up the elect choke?
  4. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    An electric choke is an electric choke. 2 wires, 1 to a ground, usually the carb itself and the other to a switched power source. Pretty simple. I went from a hot air choke to an electric and had the same questions about going over.
    James
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Brian, after looking at your set up, I'd go with a 650 cfm q-jet. I personally run an old style mechanical choke. It just a personal preference. Yours is already set up with the elec. choke, so it would be easy for you to stay with that setup. You mentioned you have a couple different adapter plates, so you should be able to bolt one on in a few minutes. Do yourself a favor though. Ditch the filter in the housing and run an external one like I showed you. All it takes is cross threading the filter housing one time and it'll look like sprinkler under your hood /forums/images/graemlins/doah.gif Don't ask me how I know /forums/images/graemlins/whistling.gif
    Pick up a cheap q-jet from a SBC and have it rebuilt for what we do with our junk and you're good to go until you can go with EFI or something like that. /forums/images/graemlins/waytogo.gif If you want help, just give me a call. We don't live that far apart /forums/images/graemlins/cool.gif
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    RIGHT ON /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif Im debating right now tho...cuz I have a Pro-Jection unit available...just needs a new harness which is like 115 bucks...so Im trying to figure which I should do....either way I'll be giving you a call, cuz when it comes to fuel delivery I dunno my a$$ from a hole in the ground.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif...but ya I just need to figure which route I should go /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif maybe just do the Q-Jet for NOW then run it, see how I like it, and EVENTUALLY do the Pro-jection, since it seems a lil more involved...and then just thro the rebuilt Q-jet into my pickup since it needs a carb overhaul anyways...but I really want my carb probs fixed NOW...gotta get my truck descent so we can all go out again soon!! /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
    but I'll give ya a call if ya dont mind coming down and helpin me out when I get ready to do this (Pizza and Beer all around /forums/images/graemlins/thumb.gif)
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    No problem /forums/images/graemlins/cool.gif Beer and pizza works for me! /forums/images/graemlins/waytogo.gif
