Quadrasteer - Ride & Drive 1st impressions
Discussion in 'The Garage' started by Twiz, Jun 25, 2002.
  1. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    WOW!!!
    Man, can that thing cut a turn! It can make a full U-turn on a 2-lane road, no-problem. Turn the RWS off and make the same turn again, the truck ends up 90 degrees to the curb.
    Big difference!
    Parking lot maneuvers, the AWS really comes though, you know it's working. It's not overly sensetive, but it is a bit quick, quicker than what I'm used too. It takes some adjusting too, normaly a guy has to pull the front end out a-bit, then turn. Not with this thing. Pretty much, point and shoot.
    A quick run down the freeway, I didn't notice much rear-steer at-all, but I only made 2 lane changes in trafic.
    Really not enough seat time to get the feel of it.
    Over-all, it really makes the truck far more friendlier to drive. Just point and shoot, all-most no driver compensation needed. It's supposed to really shine when towing, and I can see why.
    Specs and Stuff:
    - Solid axle rear suspension, 9.75 ring gear, Full-floater, C/V steering joints. It looks like it's a "14-bolt" semi-floater houseing, but I'm not sure.
    - Electric motor driven tie-rods to the steering knuckles, with a "feed-back" system and sensors to determin "requested" steering and "actual" steering. Modual has diagnostics and can store DTCs
    - The motor and rack are part of the bum-cover.
    - Rear wheel steering can be up to a maximum of 12 degrees
    Three driver selectable Modes from a single button, that steps up to the next mode each time it is depressed.
    - 2-Wheel Steering Mode. Front steering only, RWS is disabled
    - 4-Wheel Steering Normal Mode. Povides 3 phases of RWS.
    - 4 Wheel Steering Tow Mode. Provides more positive (same direction) steering than in 4WS Normal Mode
    Negative phase- Rear wheels steer in the opposite direction of the fronts.
    Neutral phase- No rear steering (cross-over point is aprox 40 mph in "Normal-Mode" and aprox 25 mph in "Tow Mode".
    Positive phase- Rear wheels steer in the same direction as the fronts.
    I love my job! /forums/images/icons/grin.gif
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I heard the rear axle is a Dana 60. That would make sense with the 9.75 inch gear. I'm curious what happens if the system fails? Like an electrical problem or something? Looks cool though.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It kinda looked like a Dana 60 to me.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What would you say (in your professional /forums/images/icons/grin.gif opinion) is the structural integrity of the rear steering system? I know it was designed for towing and manuevering, but what about the occasional off-road jaunt and in 15-20 years when it becomes somebodies off-road toy?
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    What do you think about th epossibility of someone, in several years, taking off the rear axle, throwing away the electric crap, and using it for a front axle?
    -- Mike
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    you'd have to do some major mods to it, he said that the wheels only can turn 12 degrees in the rear.
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    It probably has knuckles, just like a front, and maybe it just has bumpostop like a 644 or so. Or maybe the aftermarket could make knuckles to use it as a front....cheaper than a d60.
    Just thinking.
    -- Mike
  8. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yet to drive one, but had a long discussion about it in a grad class in vehicle dynamics...pretty advanced system, works very well from what i hear....but as far as reliability...well we wont know until 10 years down the road what breaks and what doesnt...
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    From SI200 (service manual):
    - "If a system malfuntion occurs, the rear wheels are moved back to center via an internal spring."
    - "The axle assemble is a heavier duty version of the standered rear axle on a non-rear steer truck" (That would lead me to think its a Corprate Axle -maybe-)
    - "The carrier is a 9.74 inch ring gear and pinion with a 4:10 gear ratio" (The only ratio avalible with RWS)
    This morning, I cleaned off the floor with the back of my shirt and took a closer look at the axle houseing.
    It's an odd bird for sure, I've never seen an axle houseing that looks anything like it. No Dana "diamond" cast in and the houseing doesn't look like anyother houseing I've seen, but it does have a drain-plug like the current Corprate houseings do. As stated above, the steering gear and rack are part of the bum-cover making it un-identafiable, the steering gear also covers up part of the cover bolts, so there is no counting bolt heads.
    I think this thing is completely new.
    I "heard" over the net (and you know how that can be) that Dana is makeing the axle houseing for G.M..
    I think thats as far as it goes tho', unless the carrier is a Dana 60 unit.
    You can spot one on the road easily by the bed-sides, the Quadrasteer trucks have "dualy" like bulges over the rear tires - and looks pretty dang cool if you ask me. /forums/images/icons/cool.gif
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    It's a Trailoring package, and it's obvious.
    The steering gear/motor hangs pretty low and are pushed out-away from the houseing, not ideal for wheeling. Allthough the gear is heavily protected with 1/4 inch skid-plates, that cover the gear front and back, so I wouldn't worry about that hitting.
    On the other hand, the tie-rods hang a below axle tube, but above the lower shock mount, I could see those getting snagged on the trail.
    I think it would be O.K. for mild trail rideing, but nothing extreme.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I seem to recall reading somewhere that these guys are making most of the axles for GM these days: http://www.aam.com/
