quadro- junk carburator problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Oct 28, 2002.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have a 1984 k5 with the quadra-jet carb. for the past three mornings , the choke is not opening up after warm-up.
    i have gone in and flipped the linkage myself to open it
    so i can go. this morning , no matter if i flipped it ,it
    would close again.
    the wire is hooked up and i its not all gummed up on the
    linkage , actually i think the carb is only a couple years
    old. is the problem in the choke , or is it in the thing
    (whatever its called ) that opens up the butterfly ?
    should i mess with it , or just hook up a manual choke
    cable ?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Does the wire actually have 12 volts to it? Without 12 volts the choke coil will not warm up and the choke will never open.
    Rene
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    There is a fuse for the choke. It should be up towards the top of the fuse block.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Make sure it's getting power while the motor is running. It's activated by an oil pressure switch. I believe there is a 30amp (maybe 25?) fuse towards the top of the fuse block.
    Be careful of the clip that hooks the wire to the choke. It is prone to breaking. It's a $5 connector and hard to find.
    Does your choke light stay on even though it's got power to it? If so, it's time for a new choke. All an electric choke is made of is a bimetal strip. They burn out pretty regularly. If it's not freezing cold outside it'll be hot enough to burn your fingers in a minute or so if you take it out of the carb. If it's still riveted in then the choke has probably never been replaced.
  5. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    the light for the choke goes off as soon as the engine
    has started. yes , the choke is still riveted. the wire
    is hooked up . i am going to check it out wednesday afternoon which is my evening off from my parttime job .
    is there anything else i should look for ?
