Quality heads??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Sep 3, 2001.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Need some info on where to get some quality heads for a reasonable price 64 cc chambers will do but pre-fer 58 cc closed chamber and with new valves etc. FOR A SM. BLOCK all info appreciated thx!!
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The Vortec heads off of a 96 truck are 64cc. They are around $550 for a complete pair.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. J.R.
    J.R. Guest
    check with summit, they have a good selection of heads. i prefer world products heads. for cast iron heads in my opinion they are the best.
    BIG BLOCK MAN
    "MORE POWER"!!
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Vortec's are the best deal in Iron Heads.
    If you're going to spend the $$$ for an aluminum head, might as well spend a little more and get AFR. They are THE head, and will make any smallblock run.
    Lift It, Lock It, LIVE IT!!!
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I agree with J.R.
    World Products make some of the best heads in the market.
    You definitely get what you pay for with WP heads. [​IMG]
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  6. twenty_below0
    May 16, 2001
    436
    Thx for the info and where is the cheapest place to get either the vortecs or World heads....P.A.W ??? thx
  7. J.R.
    J.R. Guest
    i have found tha PAW is a little high on a lot of things, check summit or jegs. i ordered one set of BB heads from summit and a set of SB from jegs,(world products on both), both were excellent quality and delivered within a week.
    BIG BLOCK MAN
    "MORE POWER"!!
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    world heads and dart heads. napa has them and they are a good price. vortec heads if you dont mind updating your intake too. you can find them done to older intake too.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  9. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    If you get the vortec heads i would recomend gettig the intake to match them as opposed to getting the heads drilled and tapped for the old pattern. the ports on the vortecs are different and you should have and intake that matches them. the vortec intakes are also much easier to bolt on
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  11. twenty_below0
    May 16, 2001
    436
    Thx for the info on everything guys!!!!!!! Will be getting my page up soon with pics of my K5 and some wheelin trips appreciate all the help! Mike
  12. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    vortecs fit on a 400? need steam holes drilled or not? I am planning a future up grade myself.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  13. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well there are those cast-iron vortecs that are a great bang for the buck. Which of your trucks are you planning on putting the new heads in? Edelbrock makes and intake that allows you to run your carb with the vortec heads and requires no drilling. If you're running TBI you can get an intake from GM performance parts. Im not sure about the Edelbrock intake but with GM one you have to run a line off the exhause manifold to the intake to atomize the fuel. On factory Vortec motors it plugs into the back of the intake. No, Im not full of $hit, there's a footnote about in the 2001 GM performance parts catalog.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  14. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I know pace has some vortec's they modify to fit the 400... (<a target="_blank" href=http://www.paceparts.com>paceparts.com</a>)
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
