Quarter eliptical rear suspensions?
Discussion in 'The Garage' started by sled_dog, Aug 31, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Anyone ever seen a K5 with this setup? Wondering what the highs and lows are. Seeing as the ones I ahve seen were the 2 springs and 2 link bars I would think it is pretty good for traction with the links acting as traction bars.
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Most of the set ups I have seen have used a 3 or 4 link set up and a shackle on the springs. If you used the springs as a link, I would think you would still have some spring wrap due to the pinon wanting to climb during acceleratrion. I could be wrong. I think you would have to solid mount the spring eye to the axle, too. Trying to envision the potential forces.
    There have been some pics posted here of 1/4 ellip set ups. Also there is a shortened k20/30 on the Tanner site. Look in the member discount section for their link. I will see what other pics I can dig up. I am considering a 1/4 ellip for my project. Currently leaning twards a 4 link XX set up to eliminate the need for a panhard bar.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    full size with quarter eliptic
    This just discussed. Try this link. Quarter eliptic with 44's and lots of pics. Gross flex....
    /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thanks, I am thinking it may be an option on my daily driven k5. I don't know I just want to be different but not if it were to mean sacrificing driveability or flex.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I know you can't really see it too well, but thats the kind of flex you get off that eliptical, i buddy of mine built this on a RC.
  7. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Don't waste your time with the 1/4 eliptical. You will be a lot happier using coil's or coilovers's, plus there is less fab work with the coil's and the road manner's of a coil setup is 1,000 times better. Honestly, just get yourself a custom set of leaf springs made that are longer than stock, with a soft spring rate and you will have more than enough flex. The way my springs are setup now I can easily score over a thousand forward and backward on a 25 degree ramp.
    If you are set on changing the rear suspension to a linked setup, use coilover's and the |V| configuration like MJ said, you will get a lot less binding out of the link's if they are setup correctly.
    These pictures are from when I had 4" Tuff Country ezrides up front and just a shackle flip in the rear.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I have been considering going coil outback for a long time. Kept coming back to the idea of front coils off a Dodge Diesel. Need to find out how much the back of a K5 weighs. I will put mine on the scales when I'm working on it and figure it out.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    is the front 1/4 elip txsize?? the rear obviouslly isn't.
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    doesnt look like 1/4 elliptical to me...in fact it isnt 1/4 elliptic...its a regular leaf spring with a long rear shackle from the looks of it
    Later
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    definetally isn't 1/4 elip. unless he did what I've seen some Toy boys do. You make a quarter elip and mount your rear shackle to it. That way you get more droop out of the shackles.
  13. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Maybe it's a regular leaf with a "goofy shackle".....you know, one of those extra leaves that is compressed up against the frame that allows the axle to "fall away" more....
    I think I've also heard it called a "Buggy spring"? Almost looks like a football shape when viewed from the side (postively arched spring on the bottom, negatively arched upper spring)..... if that makes any sense...? /forums/images/graemlins/smile.gif
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah thats exactly waht I mean and what it probably is.
  15. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    yep thats the buggy setup...
    quite possibly what it is...ill have to look again
    Later
  16. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    its just in the rear though...they used a leaf cut down to about a quarter of its size and mounted it upside down from the frame...not a bad idea...
    dont really know what you would call it, half buggy spring maybe?
    Later
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    3/4 eliptical sounds about right to me
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    http://www.pirate4x4.com/tech/suspension/buggyleaf/index.html pirate calls it 3/4 eliptical too. Hmmmmmmm I have an extra lift spring sitting around. Maybe the k5 has a 3/4 eliptical in its future. will double as a shackle flip, hmm only problem is getting the spring outside of the framerail. and having whatever it mounts to being strong enough to support the k5 through jumps and such.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
