Quarterpanel swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaBnn3, Aug 19, 2005.
  1. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    I picked up a rust free quarter panel for my '88 Suburban from a local salvage yard, and am wondering if I should dare try it myself. I'm not a body man or mechanic, though I've done my own mechanical repairs recently. What are the steps, and would I be wiser to take it to a body shop?
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    since it is a used panel best to take it to a shop and have them cut and install it.lots more work involved with a used panel than a brand new panel.
  3. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    Last week I replaced the front quarter panel on my 76 with one from an 80 from the junkyard. Some of the bolts were a little tough to get at and I had to cut an access for one bolt that had a clip spinning. Nothing too tough. The hardest part was the trial and error of getting the right # of shims in so the panel lined up and the door would open. I was working alone, but it would be much easier with some help.
    Good luck!!
  4. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    if you've never done any body work, i would get a shop to do it. lots of cutting and welding, easy to warp the panel with too much heat. guess it depends how perfect the truck needs to be too.
