Question: 0 Rate 1" Add a Leaves
Discussion in 'OffRoad Design' started by 1972Blazer, Jan 14, 2002.
  1. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    Question: 0 Rate 1\" Add a Leaves
    I cannt find anything on the add a leaves on the ORD web page. Are they going to match the front Rough Country 4" springs as far as width, thickness, tapper and spring pads on the ends? Where in the spring pack do they go and do the come with the center bolt?
    1972 Black CST Blazer, 350/415 HP, TH350, NP205, 4" Springs Front/Rear, AGR Variable Ratio Steering, 15X8 Ralley Wheels and 35X12.50 BFG Mud Tires.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Question: 0 Rate 1\" Add a Leaves
    These zero-rates are nothing but a simple piece of solid steel stock, 2.5" wide, 1" tall, 5" long with a hole drilled completely thru it.
    They mount under the leaf spring pack by removing the center pin bolt on the pack and supplying a new, longer bolt thru the zero-rate and leaf packs. You cut or trim the excess bolt past the nut.
    They are all the same width as the leaf packs, which are 2.5" wide.
    There are no tapers.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. 1972Blazer
    Jan 2, 2001
    238
    What is the cost of the set for the front springs?
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    $ 30 plus shipping
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
