Question about .030 bore
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stomp, Mar 16, 2002.
  1. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    I block is .030 over. I want piston rings that are .030 oversized and standard pistons or standard size rings and .030 pistons?? I'm a little confused.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    .030 pistons and .030 rings
  3. Stomp
    Feb 23, 2002
    168
    so I want both .030 over pistons and .030 rings.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yes
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Kinda confusine.. but you cant put standard rings on a .030 over piston can you... so you will need both to be .030 over...
    Confused me the first time i had to think about it a long time ago too...
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The .030 has a bigger diameter too. If you put a standard size ring on it would have a wider end gap. Imagine you have a ring that will fit on your pinky, if you try to slide it on your index finger, its not going to fit, you need a bigger ring.
