Question about 14 bolt seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by not4show, May 23, 2002.
  1. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    I took the drum off today and I need to replace that rubber seal on the inside of the drum. What's the best way to get that seal off so I can put a new one on? Thanks.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can use either a seal puller or just pry it out with a large screwdriver. Just be careful that you don't gouge the hub area where the seal is seated. I lay a small piece of wood over the new seal so that I can tap it into place without bending it. /forums/images/icons/cool.gif
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I've done those same ones several times, and Harry is right on.
    If it continues to leak after the new seal(s), then you may need to install a speedi sleeve to give the seal a clean surface to ride on.
    Once you have the drum off, inspect the spindle closely for a groove right where the seal rides. If you have this groove, you will need to do the speedi sleeve to fix the leak.
    Thomas.
