Question about a sender.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Feb 9, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What is the sender that is right infront of the starter? I was replacing my starter today and I saw this sending unit with a wire connected to it. Then I saw that that wire is cut clean threw. Is this a sender for the oil pressure gauge? My oil pressure gauge doesn't work right, and I am wondering if this is the problem. My truck is an 85 GMC with 350.
  2. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    I don,t know where is the oil sender in the gas engine.But how is the sender? Has it a cilinder form and is close to 2 1/2" long and has a single therminal in the extreme?
    Then is The oil pressure sender.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The oil pressure sender is beside the distributor.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    knock sensor
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, that makes sense. Now I know why it is cut clean then. I am no longer running the factory ESC module that works with a knock sensor. That is why it is disconnected. Thanks
    Harley
  6. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    it's a knock sensor and it tells the computer when you throttle up and down to advance or decrease the ammount of timing to give the motor i think... /forums/images/graemlins/deal.gif
  7. Can Can
    15,552
    136
    Actually, brother, a knock sensor "hears" if your engine is pinging and sends a signal to the ESC. The ESC retards the timing to eliminate the ping.
    My ESC is disconnected, but I'm not sure if I pulled the knock sensor or not. I'm betting I didn't since I don't know where it's located on the block!!! /forums/images/graemlins/tongue.gif
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    if you pulled it out, you are not running any coolant...hopefully you didn't /forums/images/graemlins/thumb.gif
  9. Can Can
    15,552
    136
    Well, I guess that answers my question, eh?? /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
  10. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    It's an oil pressure sender if its right above the oil filter and its got a cone shape guard around it. This went bad on mine and was actually leaking oil. Replaced it and my guage worked again.
