Question about changing out a power window motor and replacing w.striping
Discussion in 'The Garage' started by jjlaughner, Apr 2, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I bought new window channel weather striping and new window motors. Any tips to make this easier? I'm doing both sides! /forums/images/graemlins/tongue.gif
    I need to pull the glass to put the new channels in I'm sure. Is there an easy way of getting to the power window motor? /forums/images/graemlins/confused.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To swap the motor:
    Remove trim from interior. /forums/images/graemlins/cool.gif
    Cut hand on door while trying to reach motor and unplug wiring harness. /forums/images/graemlins/eek.gif
    Swear, then apply bandaid. /forums/images/graemlins/blush.gif
    Drill out rivets that hold motor to door. /forums/images/graemlins/cool.gif
    Cut hand on door while trying to remove motor and regulator assembly. /forums/images/graemlins/eek.gif
    Following directions that come with motor, drill and bolt regulator so it doesn't cut off your fingers when you remove the motor from said regulator. /forums/images/graemlins/shocked.gif
    Install new motor to regulator. /forums/images/graemlins/cool.gif
    Now you can determine how to get the glass out of the door, so that you can swap the weatherstripping. /forums/images/graemlins/confused.gif You can be certain that this will require more swearing and application of bandaids. /forums/images/graemlins/wink.gif
    Put glass back into door. /forums/images/graemlins/rolleyes.gif
    Put regulator assembly back into door. /forums/images/graemlins/cool.gif
    Cut hand on door while trying to position regulator assembly. /forums/images/graemlins/eek.gif
    Bolt regulator to door. Bolts should be supplied with motor, to replace rivets drilled out earlier. /forums/images/graemlins/cool.gif
    Cut hand on door while trying to reach motor and plug in wiring harness. /forums/images/graemlins/eek.gif
    Reinstall interior trim. /forums/images/graemlins/cool.gif
    Remove interior trim, plug in harness to power windows and locks. /forums/images/graemlins/rolleyes.gif
    Reinstall interior trim again. /forums/images/graemlins/thumb.gif
    Pat self on back for job well done.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    The thing is... is that is soo true
    John [​IMG]
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Thats kind of what I figured, I thought about about cutting out the area behind the carpet? /forums/images/graemlins/smirk.gif
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, i think i might "modify" some of the sheet metal behind the door panels on my rig... the holes in the door are just a little to small. make them about an inch larger in every direction... and then maybe use some cheap rubber hose cut down the middle to line the sharp metal edges and it'd dang near be enjoyable to work on a chevy door. /forums/images/graemlins/grin.gif
    j
  6. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I was able to replace the weatherstripping and channels without removing the glass. The trick is to remove the bolt that holds the rear glass channel in place. Once you get that bolt out, the rear channel can be moved away from the window and allows a lot more room to work the new stuff in place. I used the LMC seals with no problems. Some people have problems with the windows not rolling up easily after you get it done. I found that the weatherstripping on the divider bar between the window and vent window needs to be pressed in REALLY hard to seat it properly, otherwise it will bind the window enough to make it difficult to roll up.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    See I'm replacing mine because the ones in the doors now are falling apart and the glass is getting hung up on the weatherstripping and ripping it. I didn't think about the seals making it harder to go up. I did just put a rear seal on the tailgate (from LMC) and the glass won't roll up without pulling the strip up with it (when I replaced it on my other blazer there was no problem). /forums/images/graemlins/rolleyes.gif Figures.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The motor and regulator will fit through the existing holes, it's just a tight fit. They install that stuff at the factory through those holes. /forums/images/graemlins/cool.gif
