Question about chevy dual tank crossover valves
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by buckshot33, Jun 5, 2004.
  1. buckshot33
    buckshot33 Registered Member
    Jun 1, 2004
    12
    Bakersfield CA
    I've got a project I'm working on thats will be using a Tune Port Injection setup and the fuel pressure before the regulator is around 100 psi or a little less. would this be a problem for the stock electric dual tank switcher in 70's or 80's dual tank pick-ups? the order from tank to engine will be tank(s) switcher, electronic fuel pump, regulator (built into the TPI) then the fuel rail etc. the fuel pump only pushes 100 psi, I dont hink it pulls that hard. This shouldnt affect the switcher valve should it?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I don't think it would be a problem for the tank selector valve at all.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    This is what I plan to do.
    Whatver you do, do NOT pressurize the switchover valve!!
